Hello, I am trying to find out if there are fuses and/or relays that could keep my A/C pump from engaging. The system show charged, the A/C light says "on" in the dashboard, but I can physicall see that the pump is NOT turning.
Many Thanks,
Damon
1998 SL, A/C compressor will not engage
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Sounds like a bad compressor clutch gap to me... there are several threads on here about that as well as a cheap/easy fix. Take a look and search for "clutch gap" in the repair database.
- Year and Model: Many Volvos
- Been thanked: 76 times
This:
https://www.matthewsvolvosite.com/forums ... c&start=20
I have not yet had to mess with any of mine but the "bread clip" method has had rave reviews.
chernobyl1
- Year and Model: 1999 V70 Base
I'm having the same problem on my wife's '99 V70. All the lights and indicators on the climate control panel are acting regularly but the compressor will just not kick in. Its about 75 degrees out today and without A/C its a bit too hot for our 8 month old. Did the breadclip "fix" yesterday to no avail. Put a can of refrigerant on it the other day and with the compressor off the pressure was reading in the 60 PSI range. From some other threads that I've seen on MVS that seems a bit low, but would it prevent the Compressor from engaging at all?
Looking for some ideas for what else might be the problem. Tried pulling the A/C relay while the engine was running and it killed the whole thing. Not sure if that means the relay is still doing its job or not.
Stumped on this one and would like to fix the wife's A/C for mother's day. Any help would be appreciated!
1999 V70 Base, Silver - "The Torpedo" - Hers
1998 V70 Base, Green - "The Mean Bean" - His
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Try jumping the low pressure switch at the firewall line on the passenger side and feeding it in. You cannot charge up the system unless the compressor is circulating the refrigerant.
'98 S70 T5
2016 Chevy Cruze Premier
chernobyl1
Good call. I will try that first thing and let you know how it goes.
MatDesign84
- Year and Model: 1997,855 T5
Maybe I'm just being greedy, but I wish someone would write a "How to fix your A/C for dummies" thread, I would like to tackle mine after I get some other problems sorted, but with such wide spread threads covering different issues, its enough to make someone cross-eyed. Just Sayin'...
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
I've run into a similar issue with my wife's 06 V50. AC blows extremely cold for 1st 15-20 minutes on a hot day, but suddenly starts blowing outside warm air. Clutch disengages, and won't re-engage until you turn it off for a few minutes. On a 90 degree day, a few minutes feels like forever, especially with a 18 month old in the car. I tried the "bread clip" fix yesterday with zip ties instead of bread clips and superglue. I figured this would be a good way to test the fix, without the permanent adhesion of superglue. I will update once it is tested out today (another 90 degree day in NY). My only question is, is there a possibility of the plastic melting as the clutch heats up a bit. My assumption is no, being that many people have "shimmed" using this method, but that would be my main concern. If this fails, it's time to go proper and remove the plate and a couple of the washers.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
When Ac is ON the orange light at ac control panel should be OFFKlavolvo wrote:...the A/C light says "on" in the dashboard...
When Ac is OFF,then the light on the Ac control panel will be ON(for ecc climate control).
I suppose that you're talking about the little orange light just under Ac switch,because there is NO Ac light on the dashboard.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1329 Views
Last post by insession
- 19 Replies
- 8654 Views
Last post by Roger_850T
- 820 Views
Last post by skippy
- 1342 Views
Last post by RickHaleParker
- 1639 Views
