1999 XC70...
Anyone ever removed the gas tank on one of these? Whats involved?
Thanks
XC70 Gas tank removal
schmidm90
- Year and Model: 2000 V70 XC AWD
Why are you looking to remove the gas tank? If its the AWD version there is a lot involved. I had to drop the tank to get to the fuel pump but ended up cutting a hole in the floor rather than going through all that work...
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
2000 V70XC - 199k
Yes, its the AWD version. I have to get to the line(s) leaking on top of the tank. The leak is very bad and I cannot get to it by cutting a hole where the fuel pump lids are. I cannot pinpoint exactly where the leak is, but its coming from above the rear of the tank. It only leaks when the pump is on (engine running)...
I wish I could cut a hole on the floor to fix it, but it would have to be a big hole to cover the area where the leak is...
1998 V70
Near Guelph, Ontario, Canada
cannibalpeas
- Year and Model: 2000 Volvo V70 XC
Can anyone elaborate on the tank removal procedure? I'm facing having to replace the pump and can't find anything very clear... everyone just says that it's tough.
schmidm90, could you give some guidance as to where & how to make the body cuts? There are a few images here, but none that really seem to show the relative location.
v70xc
- Year and Model: V70XC AWD Turbo 1998
Yikes.
I am in the same boat. Leak coming from the top of the tank and as of yet, I am not sure where.
BEJinFbk: I don't fancy having to remove the entire rear end (suspension, etc).
I would also like to see if anyone might have picture showing what will need to be removed to accomplish finding the leak.
If I were to consider cutting out some of the floor in the back end of the wagon, are there any wires attached to the underside that I should be looking out for?
I am driving the 1998 V70 XC AWD Turbo (wagon).
I sure hope someone might have a simpler solution
Thanks in advance.
Thanks in advance.
1998 V70XC AWD Turbo
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
To all having this leak issue:
There are some pretty inexpensive inspection cameras out there.
Most have a 3' flexible neck, but extentions are available with most brands.
That may help finding the leaks...
v70xc
That is a great thought....
Could you suggest make, model, place to purchase and possible price?
I am Canadian BTW, so if you know of anywhere in Canadian stores that you might suggest, that would be greatly appreciated.
Thank you.
I was wishing to also hear of a simple way to remove the tank without dropping the suspension
Thank you.
- BEJinFbk
You can always start with a search!
http://www.dogpile.com/dogpile/ws/resul ... ceUrl=true
Good Golly, I love the net...
- 1785 Views
Last post by vtl
- 16 Replies
- 965 Views
Last post by Brickbox8398
- 672 Views
Last post by cscollins
- 622 Views
Last post by 93Regina
- 1215 Views
Last post by Sommerfeldt
