2000 S70 Immobilizer
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The problem can be many things but one of the most common is the antenna ring that goes around the ignition key lock cylinder.
The first thing to do is to unplug it and spray some contact cleaner or WD-40 into the connector and then plug it in and unplug it a few times to clean any oxidation off the connections. The signal is a very low amplitude and very fain corrosion will block signals. Sometimes the antenna ring can be faulty but many get replaced the problem is gone only because new part has clean terminals. The antenna ring is a winding of wire and there is nothing to wear out. The steering column trim covers come off and the antenna ring is there in the open then.
dearest nameless
- Year and Model: S70 GLT SE, 2000
Might sound weird and basic but I had the same problem in my 2000 S70 GLT SE, and replaced my fuel filter and haven't had any problems since. (A few weeks) Turns out the original fuel filter was still on the car, full of gunk, thirteen years later.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
+1 on the antenna ring. This is a very common problem with 1999-2000 models and a very easy/cheap fix.
Stay away from that dealer.
'98 S70 T5
2016 Chevy Cruze Premier
- 24 Replies
- 5346 Views
Last post by xanthefin
- 610 Views
- 2217 Views
Last post by DutchvolvoC70
- 835 Views
- 10 Replies
- 6208 Views
Last post by GrumpyOldMan
