Oil in Turbo Intake 2000 V70 AWD
VoVo
Year and Model: 2002
Post by VoVo »
While replacing my turbo because of a bad bearing, I noticed oil was in the intake hose. I suspected this was due to the turbo failure, but after replacing the turbo, I noticed the same oil was present in the new turbo intake. What could be causing this? I do not have any impact(currently), except for the presence of oil. What can I do to correct this?
Thanks in advance,
Vovo
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Sounds like your breather box (oil trap) is full or nearly so. Time for a PCV job.
5 others that came and went
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Hey There,
This oil is getting in there because of the PCV system. It dumps the crank case gases into the intake, before the turbo. If it seems like it is a lot of oil, then more then likely you need to replace the PCV system.
VoVo
Post by VoVo »
I suspected as much...I guess I'll order the kit.....minus 10% :-)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
WAIT!
Don't order URO hoses that come with that kit. Call them up and request OEM Volvo hoses for the one into the side of the oil seperator box and the one from the box to the PTC connection on the turbo intake hose.
Trust me, you will make your life easier.
'98 S70 T5
2016 Chevy Cruze Premier
