My electric sunroof won't open after I had to disconnect the battery cables in the engine bay to get to the O2 Sensor connection below. It was disconnected for about 45 minutes. I have already pulled the fuses and the other int. accessory fuses, but they look good. I went ahead and changed the fuse just incase and still nothing. Is there an iternal fuse in the motor? Or possibly the car has to run through a few drive cycles before everyting comes back online ? Any other ideas:?:
Thanks
Sunroof Won't Open After Battery Was Disconnected??
Disconnected Battery, Now Sunroof Won't Open
brandonbeach14
- Year and Model: 2.4T V70, 2001
brandonbeach14
Update----I found a recalibration process for the sunroof if the battery has been disconnected, but it didn't work. The sunroof is still stuck shut. Everything else on the car is working fine. I guess I'll just give it time and see if it starts to operate eventually.
JRL
- Year and Model: Several
- Been thanked: 16 times
Did you lock and unlock the car three times with the key?
(NOT the remote)
(NOT the remote)
brandonbeach14
I didn't. Should I disconnect the battery again and then do it?
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Yes, try JRL's tip first. If that doesn't work, I'm going to bet that you didn't reconnect the battery with the key in position II? If not, pull the battery cables, touch them together, place the ignition in position II, reconnect the positive cable last, then do not enter the car until the SRS light goes out (or until 2 minutes has elapsed with it on, whichever is first)--this lets the computers initialize and startup properly on the P2 cars.brandonbeach14 wrote:I didn't. Should I disconnect the battery again and then do it?
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
1999 S70 GLT
brandonbeach14
No, I didn't have the Key in position II. I'll try JRL's 1st and then yours if needed and let you know. Thanks again.
This happens to me every time I do a battery. SO I will tell you all how to get it to work.
Roll down drivers window and close door
lock car and wait 1 Minute.(this will set the alarm system even if siren is bad)
Reach in through open window and open door(will set off alarm)
Use key in door to shut off alarm
Sunroof works.
Have been doing this for seveeral years and works every time.
Sunroof works.
brandonbeach14
DIsconnect the battery again and then do the above? Or do it w/o disconnecting the battery? Thanks
VCA
Try beetlebob's procedure before disconnecting the battery; no harm in seeing if it works. If not, then go through the whole disconnect, key in II, reconnect process.
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
brandonbeach14
Well, I have tried every suggestion above with no results as well as the calibration process in the Haynes Manual. How long should I leave the battery disconnected? I only left disconnected for a couple of minutes before trying each above. I also don't have a remote for the car, but I'm not sure if that would be an issue or not. Thanks again.
- 806 Views
Last post by beigg
- 25 Replies
- 13608 Views
Last post by wizechatmgr
- 712 Views
Last post by twiggs462
- 1130 Views
Last post by racertim
- 9 Replies
- 1807 Views
Last post by IslandV70
