850 / S70 wagon tail light redux!!
This topic is in the MVS Volvo Repair Database » 850 / V70 Wagon Tail Light Polishing
phat78ta
Year and Model: 94 850 turbo wagon
Post by phat78ta »
Hello all, and welcome to the fix you all have been waiting for!! :?
I Have been fed up with my faded/chalky headlights for some time now, and have been working on a solution for this annoying problem. I found a post somewhere(can't for the life of me remember where) about lens renewal. it was for headlights, but sounded feasable for tails as well. I figured it would be worth a shot, as I wasn't ready and willing to shell out $75-$100 on each "new to me" used lens on Ebay, nor the $275 i saw for an aftermarket kit. What was the wost I could do? Ruin the almost unusable lights? :mrgreen:
You will need the following(dependent on how bad your lights are):
A D/A sander or electric random orbit sander
Various grits of sandpaper
120(if needed)
330
400
800
1000(if needed)
2000(if needed)
lots of time and patience 8)
I started by removing the lights and getting them to a sturdy work place. I ended up making a jig of sorts to hold the lenses out of a 2x4. The important part is that you need to be able sand to the edges of the lens with ease.
starting with the 120 grit( my lenses were really bad- see pics) I used my sander to get the bad chalking off. This took many pieces of paper, as the plastic is extremely hard and eats the grit quickly.
Once I got through the heavy chalking, crazing and pitting, I switched to the 330 grit paper to take out most of the sanding scratches.These were fairly light, but the smoother the better. I used the factory embossing and mold marks as a guide, once I got those removed the lens was fairly free of pits and crazing. Then on to the 400 grit, and then the 800. At each paper sheet change, I wiped the lenses off with a damp rag to clean them a bit, and also to see progress.
I cannot tell you how long to sand, how many sheets it will take and how much time this will take, as all lenses will be different. However, I did the lower light in around an hour of constant sanding. The key is to keep the sander moving to prevent heat build up, and be careful around the edges as the lenses will chip an edge easily if you catch the sander on them.
I did this all with dry paper, but you can use wet/dry paper as well. I just found it less messy to do it dry.
If you take your time and are careful, you will see great results. my next step is to take the lenses and have them clear coated to prevent the UV damage again.
Hope this helps someone save some money on new lenses. Cheers!!!
Before:
Tail Light 1.jpg (96.39 KiB) Viewed 2087 times
Tail Light 2.jpg (96.39 KiB) Viewed 2087 times
After:
Tail Light 3.jpg (102.83 KiB) Viewed 2087 times
Tail Light 4.jpg (143.83 KiB) Viewed 2087 times
Just a little more eye candy- I do so love these bricks...
Tail Light 5.jpg (65.35 KiB) Viewed 2087 times
93 850 GLT sedan 156K
94 850 Turbo 189K
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
Wow I tried doing mine by hand and polishing them with jewlers rouge, did you remove the lights ?
phat78ta
Post by phat78ta »
I did remove them from the car. Also, jewelers rouge will not get out the damage. it doesn't have the grit needed.
94 850 Turbo 189K
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Nice work, phat78ta. This is going in the Repair Database (give it 24 hours).
Also -> Amazon link
Red-Arrow
Year and Model: 850 T5 1995
Post by Red-Arrow »
Why didn't you compound them in the end with some G3 paste and a mob?
Life would be enjoyable if it wasn't so painful to live.
phat78ta
Post by phat78ta »
Red-Arrow wrote:Why didn't you compound them in the end with some G3 paste and a mob?
I am having them clear coated, so the 800 finish is good.
94 850 Turbo 189K
850TurboTurtle
Year and Model: 96 850T, 05 S80T6
Has thanked: 12 times
Been thanked: 5 times
Post by 850TurboTurtle »
That's impressive. Thanks for the info - I'll be adding it to my spring cleaning list...
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
damn...those were bad. I wouldn't clearcoat them at this point.
When I bought my first wagon, the tails were about in the same condition as yours are right now after working them over. I used a Porter Cable with some Novus plastic polish and they looked brand new.
My current wagon has been outside it's entire life. When I bought it 3 years ago I did the Novus to them to make them look new again. Every year it gets a machine polish at which time I do the tails again, then it gets waxed 3-4 times a year. They still look new.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
