Trouble Installing Water Pump - 5/8" metal line won't seal
takeiteezeee
Year and Model: 940GL 1992
Post by takeiteezeee »
Hi, I have a 1992 940GL and I'm having trouble installing the water pump correctly. There's a 5/8" metal line which attaches to the water pump that I can't get to seal correctly. I don't know what this line is for, maybe the air conditioner? There isn't a typical male/female type fitting so I'm not sure how attach it.
Thanks in advance for any help!
Jim
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
the pipe should have a rubber seal on it and a bolt holds into pump.
Put the seal on the pipe against the ridge, Lube the seal with pure antifreeze so it will slip into hole in back of pump.
mojomello
Year and Model: 1994 940 turbo
Post by mojomello »
I had trouble with mine too. I went to Ace hardware and bought a couple of o-rings and used them in combination with the seal that came with the water pump. Sealed it right up, no problems.
