P0172 code broken elbow
Thanks for the great post. I had the same code and didn't know of this particular elbow 'till I saw this thread. Just found mine was bad and after liberal application of foul language and curses to Volvo engineers, was able to effect the change. I would recommend using a needle nose about 12" or longer if you have one, to hold the insulated line while trying to remove and install the elbow. As well, if you happen to be changing out the alternator or p/s pump change this at the same time. When putting in the new one I found it best to put the nipple end on first and then, with the one hand, aligning the hose and elbow to mate them up.
Red-Arrow
- Year and Model: 850 T5 1995
- Been thanked: 2 times
I get a similar code of 232 and 315, I know 315 is idle control valve but I think I found the same problem with the vacuum hose from the turbo side. It was cracked and showed signs of perishing but I can't tell if its allowing non-metered air into the engine triggering the fault code 232. I thought 22mpg combined was ok for a T5, are you guys saying thats bad?
Life would be enjoyable if it wasn't so painful to live.
digitalnomad
- Year and Model: 2003 & 2007 XC70
My elbow looks fine, but I'm wondering about the other end. Can someone please describe or post a pic of where the other end of this hose connects?
1995 850 Turbo Wagon
A2 has trouble codes 231, 414
digitalnomad
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's the top most (meaning towards the top of the picture - connected to the valve with the fat hose) of the three hoses near the turbocharger here:
'98 S70 T5
2016 Chevy Cruze Premier
digitalnomad
Which number on this photo? Thanks for the help.
digitalnomad
jblackburn
3. Nice numbering, I'll haveta steal that for future reference
'98 S70 T5
New to this forum, but not new to forums in general. Sorry to rehash this thread but I desperately need some assistance with this issue.matthew1 wrote:Second one, part #9155862. You don't need to remove the coolant hose if you have the dexterity of an elf. Otherwise, it helps. I used a clamp on both ends because it repeatedly blew off one side or the other.![]()
When I remove my coolant hose the coolant comes flushing out. What should I be doing so that isn't happening?
Also per some IPD installation instructions* it says I should "pull off the fuel rail cover, disconnect all the injector connectors, and move the harness out of the way." Is this necessary? I can't tell from your pics if you've done this or not.
*See attached
TIA,
Staan
PI-318 VACUUM ELBOW INSTALL GUIDE.pdf- (129.58 KiB) Downloaded 401 times
- Has thanked: 2864 times
- Been thanked: 1332 times
Some coolant will come out, blame gravity. Don't do this when the car's hot/warm, obviously.
No, you don't have to remove the fuel rail, spark plugs etc. But that would make it much easier.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I would drain the coolant first, 2 quarts or more. If clean, save it, and use it for refill.
- 10 Replies
- 3464 Views
Last post by josephodrain
- 9 Replies
- 2631 Views
Last post by ColoradoPaul
- 10 Replies
- 3918 Views
Last post by Redmerlebaby
- 11 Replies
- 2354 Views
- 1496 Views
Last post by callahanoffroad
