Transmission dip stick help!
This topic is in the MVS Volvo Repair Database » 2-Stroke V8 Volvo Dragster
brad98S70
Year and Model: 1998 S70
Post by brad98S70 »
First time user, great site!! I cant pull out the transmission dip stick. I used nearly all my force and nothing. What more can I do? Pull hard as I can? Can I cause any damage? Thanks ...
jimmy57
Been thanked: 320 times
Post by jimmy57 »
WD-40 at the base of the colored part of dipstick where it goes into metal tube. It can rust there and make the rubber o ring that seals disptick bind up in the tube.
brad98S70
Post by brad98S70 »
Thanks jimmy57, going to give it a try right now
Been thanked: 470 times
Post by cn90 »
Rotate it using a pair of pliers.
But first, buy a new dipstick from dealer, about $6 or so:
http://www.eeuroparts.com/Main/PartDeta ... id=3502973
Known problem in this car, sometimes it just breaks and you have to fish out the broken part.
So again, get a new dipstick BEFORE you even touch this thing!
brad98S70
Post by brad98S70 »
OK, sprayed wd-40, no luck! I'm going to use more force. Hope I dont pull the tube out with it....But I'll buy a new stick b4 I try again...
brad98S70
Post by brad98S70 »
Thanks for the suggestions.. Had to muscle it out, twisting and pulling with pliers. Obviously no one checked this in a long time. Need a drain and fill I suppose!
