If worse comes to worst you can always use one of these: http://www.summitracing.com/parts/FLX-31147/
ive used several on some older muscle cars and they work flawlessly and are adjustable just follow the instructions and wire an inline fuse, on the Volvo you may need to make a small hole in the fan shroud for the probe to go through and into the rad fins. However factory stuff is usually the best to stay with so id start with testing that fan according to Ozark Lee's instructions besides you want to make sure the fan is not the problem first.
850 running hot
Overheating? Ground your Fan!
hey guys I just looked around for lose wires, turns out I did not reconnect a black ground wire. (remember I changed the engine) the wire has a round connecter and I found a bolt on the block that was doing nothing so I bolted the wire down. could this have been my problem,,, my fan was not grounded. I will take it for a test drive tomorrow.
- Year and Model: Many Volvos
- Been thanked: 76 times
Absolutely.could this have been my problem,,, my fan was not grounded.
Swedish Chef
- Year and Model: 850 1995
Drive On
Another satisfied customer!
Glad you found the problem.
- 23 Replies
- 989 Views
- 17 Replies
- 4340 Views
Last post by villagepc
- 48 Replies
- 11069 Views
Last post by bmdubya1198
- 924 Views
Last post by Ozark Lee
- 1013 Views
