I really have no idea what is going on and I am hoping someone can point me in the right direction. First I will note that this is a manual transmission so that the following makes sense. When I slow down a bit too much for a gear, but sometimes don't have a chance to downshift (1500 ~ 2000 rpm range), the car jolts once or twice when I am speeding up. It is not right when I accelerate though, it doesn't jolt until I have already started speeding up a bit. If I am very light on the gas, it doesn't happen often...but when I accelerate hard, it always jolts. It does this in second and third gears...haven't really noticed it in other gears. It has not done this in the last 11 years, so I know it is something new. Also, if I don't give it enough gas when starting into first gear, I sometimes get the same jolt...so i have to rev the engine a bit when starting off to prevent it from happening. Also, it is not throwing any check engine codes
My thoughts of possible problems are:
ETM/throttle body/MAF/oxygen sensor
Air filter (it is dirty and needs to be replaced, but I am not sure if it would really cause this)
Spark plugs/wires/distributor cap/ignition coil
fuel filter or fuel injectors
clutch slipping
cylinder misfire
I have already cleaned the throttle body, but that did not seem to make a notable difference. I wish I could say I keep up with replacing everything on time, but I don't have the money right now to spend unless it is a necessity. Thanks for any input!
2000 S70 stuttering/jerking when at low RPM
Gatekeeper21
- Year and Model: s70 2000
JRL
- Year and Model: Several
- Been thanked: 16 times
Learn your car
You do not have plug wires, you have 5 coil packs
I would lean towards
ETM
MAF
Bad or cracking coil(s) and check everything else you mentioned except clutch, that's not a clutch symptom
MILEAGE always helps when you ask a question
ETM
MAF
JRL
I forgot
Add possible dirty fuel filter
Fuel pump issue
Fuel pump issue
- Has thanked: 2864 times
- Been thanked: 1332 times
If your spark plugs have more than 15k miles on them I'd put OEM Volvo plugs in, and for sure a new air filter. Run some fuel system cleaner in it next fill up. Do the simple things first.
Gatekeeper21
Thanks for the info, glad to hear that it is not clutch related. Wasn't sure about the wires...when i looked online, i found a site that supposedly sold ignition wires for the s70, so i thought they were separate parts (obviously wrong info there). I took the air filter out yesterday and drove it around the neighborhood, but it didn't make a difference. Is there any way to test the MAF or ETM since the check engine light hasn't come on? Can I clean them in any way? Also, it is currently around 190k miles
It has been quite a while since i have replaced the spark plugs, so i will go ahead and do that and check the coils. If that doesn't seem to make a difference, i will run some fuel cleaner through the system
- 31 Replies
- 6400 Views
Last post by Krisemann
- 962 Views
Last post by arvik
- 2162 Views
- 33 Replies
- 7450 Views
Last post by styoung94
- 13 Replies
- 968 Views
Last post by Keshavsmith
