Idle problems
I got an Volvo V70 XC AWD, I see that the Air mass meter is unpluged when i got the car, when i plug it in is that the car idle till its hot and then it dies... when we drive with it in the car jurkes a lot, it happens til it goes to 4000rpm. But when we plug it out it pulls fine with good power. On the idle side, it plays from normal idle to 2500rpm it goes up and down, up and down, sometime when you drive a bit it stays normal when stoping at stop or robot. What can I do to fix it? Could it be the idle sensor valvle and wher do i locate it on the motor?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Sounds like the mass airflow sensor is just bad.
'98 S70 T5
2016 Chevy Cruze Premier
DouglasTrumbo
- Year and Model: 1993
These cars acutally have a computer controlled idle. When the car senses that the idle is too low or high it will adjust the gass intake to a certain degree to try and get the correct idle speed.
JRL
- Year and Model: Several
- Been thanked: 16 times
For God's sake just replace the MAF sensor
Buy a Bosch (same as OEM VOLVO boxed) about $120 or less, (vs $250) takes 4 minutes to change
- 1087 Views
Last post by 93Regina
- 579 Views
Last post by 89jordan240
- 10 Replies
- 3800 Views
Last post by durk80
- 11 Replies
- 4131 Views
Last post by straubman
- 1587 Views
Last post by Build
