Do what Tailor wrote. That's the easiest.
I tried it the other way and it wasn't what I would call a good time.
Turbo hose about to go south
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- LamboSE5
- Year and Model: Empty
Cool. I'm still looking for some advice on changing my Turbos CBV diaphragm -- can it be done without removing the turbo...
Maybe a thread on removing/rebuilding the turbo would be good. Still lookin'
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
http://www.pelicanparts.com/euro/catalo ... .htm#item0
It is an aftermarket hose (URO), but no one else seems to stock it.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
confused_al
- Year and Model: 1996 TLA wagon
Buy the genuine hose from a Volvo dealer, it will cost you $3 more than URO hose but you don't have to replace that again in 3 months.
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I recently replaced my turbo coolant inlet hose (on a '97 855 GLT at ~148k miles) after inspecting it per Tailor's advice above, and it was getting a little soft and puffy at the connection to the metal tube that connects to the turbo housing. There always seems to be a lot of oil around the turbo, which probably accelerates the degradation of the rubber, plus that is probably the one of the hotter spots.
I bought an OEM replacement inlet hose from DW Volvo in TN from Don Snyder. It cost $6.50 and it is part number 6842190. The two hose clamps are part 988023 and cost $1.75/each.
I did most of the repair from underneath the car after jacking it up and placing it on four jackstands.
I basically followed Tailor's procedure to remove the bottom hose clamp and the upper banjo bolt from the turbo housing. Then when you get the tube and hose out of the engine bay you can remove the upper hose clamp, which is virtually impossible to loosen (at least on mine). I did not remove the heat shield.
The picture below shows the state of the original hose, covered in oil at the top and somewhat hard to access: To remove the lower hose clamp I found there was an angle from the top of the engine that, with a 7mm socket and a 1' 9" extension (the longest I've ever had occasion to use), I could reach and loosen.
The picture below shows the extension going down to the hose clamp before I attached the ratchet and loosened it. Once I got the lower hose clamp a little loose, I got under the car and spun it around so I could finish loosening it with a 7mm ball driver. To get the old hose off the bottom nipple I had to gently slice the old hose with a knife taking care not to nick the nipple. I cleaned up the deposits on the nipple with a brass brush.
Then I used a 17mm socket and ratchet to loosen the banjo bolt at the top of the turbo housing. I did this from underneath the car and it was a little difficult. There is a heat shield on the firewall that is pretty sharp. Once my knuckle heals up I'm going shopping for an extendible 1/2" drive ratchet (the 10" handle on mine puts your knuckle right where the shield can get it).
As Tailor said there are two copper washers on the banjo bolt you have to keep track of. Once you get the tube and hose out of the car, you can remove the upper hose clamp, get the old hose off and clean everything up. I made a mental note of the angle (and took the picture below) showing how the tube fit to the hose so that I could put the new hose on at close to the right angle. The old copper washers had a little green corrosion and some compression marks but they didn't look too bad so I reused them. I cleaned up the banjo bolt hole and threads and the tube, and then installed the new hose. I needed to orient the hose clamps so the nuts faced me downwards -- that made it easier to tighten them up when I was under the car. I loosely attached the banjo bolt at the top and attached the hose at the bottom nipple. I found I needed a little liquid dishwashing soap on the tip of the nipple to get the hose to go on. Then I tightened everything up, refilled the coolant, burped the system of air and refilled about 4 times, checked for leaks, and it's all good!
- 1054 Views
Last post by jmscdgn
- 10 Replies
- 1674 Views
Last post by sleddriver
- 692 Views
Last post by apollo13
- 388 Views
Last post by Iceman12596
- 53 Views
Last post by M0125
