I have searched everywhere on this site and google and still can't find instructions and pictures, on how to change the right engine mount. If anyone can please help, it would be greatly appreciated.
Okay first remove the passenger side wheel I would remove the passenger side in fender or just remove enough of it to pull it out of the way then you will have good access to the mount. Then you'll need to suppport the engine to take weight off the mount raise the engine/trans as necessary for clearance, note any locating pegs or directional arrows as an aid to refitting. Take care not to raise the engine/trans by more then 30mm, otherwise the inner left-hand CV joint will be damaged. I hope this helps...
