Blinking climate control lights? Codes?
S70 Guy
Year and Model:
Post by S70 Guy »
1993 850 GLt 174K. Started a few days ago. When I turn the car on the AC & REC lights blink about 18 times then goes out. Any ideas what this code is for.
Thanks
1998 S70 GLT 145K
1993 850 GLT 172K
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
The climate control system has logged an error code. Check your codes to see what it is.
Also -> Amazon link
S70 Guy
Year and Model:
Post by S70 Guy »
how do I check the codes?
1998 S70 GLT 145K
1993 850 GLT 172K
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Most parts stores will read your codes for free but they will not usually reset them. Get them checked and report them back.
T2
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Come on, he has the little black box under the hood next to the windshield fill lid. Most autoparts stores won't know what to do with this '93 model. Anyway, go to those boxes, and take the lid off of them and you'll see 2 boxes...one marked "A" and the other "B." With ignition switch off, unclip the lead wire (the one that looks like a probe on the end of it) and insert it into socket "1" of module boxe "B." There is a red light there that will blink and you have to read the number of times they blink. Now go turn your ignition on and then go back to the boxes and push the button on box "A." (have a pencil or pen ready.) The light will begin to blink in a series of 3's, such as 2 blinks, then one then three, etc. Press the button again for about a second and there will be another series of 3 blinks. write these down as 2-1-3 (for first example). Do this until the series of blinks are the same series of blinks as you got the first time. These are your codes that you need to report back here. Then we can help you. All codes have to be read before the codes are reset. To reset them, hold the test button down for 5 seconds then release it...the LED light will go out. Then turn the ignition off. If you turn the ignition switch on again with the test lead in socket 1 of module B and press the test button and there are no codes, you'll get a 1-1-1 code from the blinking light. Hope this helps.
I have a Haynes Repair Manual (you can buy it at most auto parts stores for the 850 and it costs less than $20) which has all of this information in it, including the codes...very usefull and highly recommended.
S70 Guy
Year and Model:
Post by S70 Guy »
OK the codes are 211 & 414, I turned the car off and back on to reset the codes but I still got the same codes.
1998 S70 GLT 145K
1993 850 GLT 172K
MadeInJapan
2-1-1 = Driver's side damper motor position sensor open circuit or shorted to 12 volts.
4-1-4 = Driver's side interior temperature sensor inlet fan shorted to earth (ground).
To reset, hold the test button down for 5 seconds with the test lead in socket 1 (and ignition on). Then turn the car off and let it set for a few seconds, turn back on and see if you get the codes.
The temp sensor inlet in a little hole located above the grab handle above the door on the driver's side. Although this sensor is fragile, you can use some compressed air or vacuum cleaner to clean it out...this may be all it needs. Not sure of other repairs on this system if the codes come back. Hopefully others will chime in.
steve3007
Year and Model:
Post by steve3007 »
I had a 414 code show up on my 95 850 just once but fortunately it went away after a reset. I suspect this code happens if the fan motor overdraws on current at startup on a cold morning. However, on the other hand, your fan could be snuffed and needs to be replaced. A DIY job if you don't mind pulling the dash apart.
Steve L
98 V70 T5
S70 Guy
Year and Model:
Post by S70 Guy »
Thanks for the info guys. THIS SITE IS GREAT!!!!!!
1998 S70 GLT 145K
1993 850 GLT 172K
turbotim2
Year and Model:
Post by turbotim2 »
My wife's 96 850 GLT has the same blinking lights however no codes have been logged. Any ideas on this?
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
