I was driving to work and something happens to my V70 that I have never seen before.
The following happens simultaneously:
The Brake light comes on (not the parking break light - the other one that means your break fluid is low).
THe ABS light comes on.
The tripometer and speedometer readout only list dashes.
The Speedometer stops working - drops to zero.
I lose alot of power - it feels like the rpm is 1/3 normal.
My only thought is that it is an electrical issue.
Also, the check engine light is not on - so there will probably not be a fault code.
Thanks.
V70 - year 2000 - 195k miles.
Strange Issue - Electrical??
Same thing happened to me. I replaced the ABS module and that did the trick. You can buy refurbished ones on line and it is an easy replacement. I found out how to do it online. Step by step instructions. Saved me a lot of money.
OOOOkkkk, looks like you are correct - there's a few posts about this issue with the identical problems listed.
So, a followup question for anyone: Can I drive my car after I disconnect my ABS module? I'm not sure if I can fix it myself or not until I take a look at it.
Man, I love this site - the information is priceless!
I found a few links...The bba-reman is a solid company - I sent an ABS unit to them for my other volvo - an S80, but it had different issues.
https://www.matthewsvolvosite.com/forums ... ule+repair
http://www.bba-reman.com/content.aspx?c ... ons_repair
http://volvoforums.com/forum/volvo-v70- ... air-15635/
2000, V70 Wagon, 307k+, 2.4 liter, awesome.
2000 S80 (N/A)
1994 850 (N/A)
1985 740 (N/A)
2000 S80 (N/A)
1994 850 (N/A)
1985 740 (N/A)
- 645 Views
Last post by Spearmint
- 4632 Views
Last post by fmwaz
- 1118 Views
Last post by volvolugnut
- 1845 Views
Last post by postrecords
- 679 Views
