P2 V70 ATF Flush/Change?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
the torx55 in the bottom of the last photo is your fill port.
Correct fluid level is filled until it runs out of the removed TX40 center plug shown in first photo with engine idling 10 or more minutes but not driven. The 17mm drain plug has a 3 inch (or close to that) tall pipe that goes up in trans and when it is overfilled it will run down pipe and exit through the hole when tx40 plug is removed.
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
Drain plug views
Drain plug.jpg (54.03 KiB) Viewed 2818 times
Drain plug photo.JPG (225.57 KiB) Viewed 2818 times
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
Thank you gentlemen! It all worked out as advertised and the drawings and photos were very helpful! Now....has anyone dared use a synthetic for an extended time with no problems?
Sim
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
You can fill through the radiator hose or from the torx 55 fill hole on top of the transmission. Someone asked about the torx bolt (centered in the bolt) for leveling and where to get it- Tasca sells it according to others on S.S., but I never saw a part number discussed: http://forums.swedespeed.com/showthread ... -Automatic
Has thanked: 1609 times
Been thanked: 4064 times
Old thread alert
