Front Brake Rotors
ykfc
Year and Model:
Post by ykfc »
Are they all 5 studs for a Volvo 95 850?
Can I tell withou taking off the wheel to inspect it?
Thanks. :?:
JDS60R
Been thanked: 3 times
Post by JDS60R »
Yes- all are 5 studs on 850's. You can look at the studs or remove the hubcap to inspect
Retired
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I believe the '93 850 was the only year that had 4 stud hubs.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
ykfc
Year and Model:
Post by ykfc »
Thanks. Do you guys replace the Rotors whenever the front pads are replaced? My mechanics didn't after checking the rotor a month ago. Now my son is complaining the brake is not as responsive as before. He said he has to press harder and deeper. I have similar feeling too but don't know if it has to do with the rotor. What do you reckon?
da7
Year and Model: 1997 S70 N/A 20V
Post by da7 »
probably more to do with the new brake pad and its friction materials, what pads u changed to?
ykfc
Year and Model:
Post by ykfc »
da7 wrote:probably more to do with the new brake pad and its friction materials, what pads u changed to?
it was changed to Bendix pads
holler1
Year and Model:
Post by holler1 »
If the old pads were original equipment type and the new ones are semi-metallic, they might not seem as responsive and require a little more pressure. I wonder about the comment that he has to press "deeper". If the pedal feels spongy or goes down close to the floor, the lines might need to be bled. Were the calipers or lines changed?
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
da7
Post by da7 »
don't think bendix is one of the better ones of the pads out there...
but there's no reason to change a rotor when u change pads unless the rotors are worn down or close to its minimum thickness, or warped to the stage that if you try to machine it, it will go below its minimum thickness... that's unless you want to spend extra money..
vjaneczko
Post by vjaneczko »
Pads can get changed three or four times before you need to change the rotors, but it depends on your driving habits.
A mushy brake pedal means there's probably air in the lines and should be bled.
Not sure on Bendix pads; I know the Akebono pads are really good and highly recommend them.
2006 S60R - For ME!
jimmyboy
Year and Model: 1998 S70
Post by jimmyboy »
I used Mintex pads and Centric rotors on both of my S70's and I'm very happy with them. When I got the 99, you could hear the brakes squealing from when my wife turned the corner 1/4 of a mile up the road.
I've always changed rotors every other pad change - I've never had rotors last 3-4 sets of brake pads without warping.
