Bad news: Reduced Engine Performance '04 XC90
BlackXC90T6AWD
- Year and Model: 04 XC90
error codes p2122 and p2121 also reduced engine performance i basically have no throttle response also.anyone have any ideas
BlackXC90T6AWD
thanks man looks like im looking at acellerator pedal sensor problems well now that ik whats wrong time to take it to a mechanic!glenwyatt wrote:This site may help you....
http://www.actron.com/code_lookup.php
Here's a question for everybody out their in Volvo land....As I understand it, and correct me if I'm wrong, if that sensor is replced does it have to be codes somehow from volvo before it will work? I'm asking because so far I haven't had any problems with mine (knocking on wood) but if (when) I do, can I just replace a part like this and call it a day or is this something that does require that I bring it in to have them re-code it? Or can I buy a VIDA/Dice setup to do it?
- Has thanked: 2857 times
- Been thanked: 1332 times
Hey, I've seen that list somewhere... now where was it?glenwyatt wrote:This site may help you....
Oh yea...
BlackXC90T6AWD and Glen, I wish I knew if a pedal sensor was in the CEM loop and needed mating or not. But I do not. A handful of people do know on this board and perhaps one will pop in.
BlackXC90T6AWD
well interestingly enough it wasnt the ETM it was the A/C compressor clutch it crapped out. causing the ECM fuse to blow which also controls the ETM. this left me stranded but i'm glad that it caused the fuse to blow cause i would have caused engine damage driving.
- 13 Replies
- 3988 Views
Last post by Botbasher
- 2998 Views
Last post by mickenann
- 627 Views
Last post by Windmu20
- 276 Views
Last post by ArrowNought
- 13 Replies
- 1561 Views
Last post by firstv70volvo
