how do I remove the rear bumper cover of 2000 S80
You still have 4 bolts to remove. Acess the battery area in the trunk. On the back panel, possibly under small foam covers, you will find 4 13mm nuts to remove. you will have to remove the battery to get one I believe. If the rivits are out, just slide it back. One more thing, do not forget to remove the connector on the rightside for the FM antenna. You will have to lower the panel on the right side (the panel to get to the taillights) to access this connector. I hope this helps.
- 1351 Views
Last post by mike:
- 650 Views
Last post by Oka
- 1672 Views
Last post by erikv11
- 10792 Views
Last post by 850TurboTurtle
- 1221 Views
Last post by treestone27
