Creaking on RH front wheel
milesursogood
Year and Model: 850 T-5, 1997
Post by milesursogood »
Lately, I've been experiencing creaking noise on the RH front wheel when slowly going over speed bumps. What advice are there to diagnose this problem?
1997 850 T-5 142k miles - Mobil-1
Has thanked: 311 times
Been thanked: 817 times
My advice is check the basic suspension components.
First: check the spring seat. Under the hood, put a wrench on the big nut on top of the strut tower. Try to rotate it. If you meet resistance, then the rubber of the spring seat is still intact. If the nut is able to spin around, it is shot.
Second: pull the right wheel and have a look around. Check especially the attachments of the sway bar end links. Look for cracked rubber boots, look for any play in the end joints of the various parts. There should be none. Also check out the metal backing plate on the brakes, they can rub, but it doesn't sound like that.
milesursogood
Nut is able to spin on the passenger side. So is the spring seat or strut mount that needs to be replaced?
Nut spins around = badly broken spring seat.
Of course it is possible other parts are bad. Because you have to totally remove and disassemble the strut tower to fix this, consider changing other parts now if they are really old or worn.
Spring seats is another on of those parts where the aftermarket items tend to just fail quickly. IPD makes a heavy duty one that is OK, otherwise go with Volvo brand or even better, Volvo branded to fit an XC90. The latter are heavier rubber they last a long long time.
Oh and when the struts come out, you need to get the front end aligned. Another reason to not have to take it out again soon for another broken part, and to check out the other side now for worn parts.
EDIT: I'd give this a look, I have bought other things from this person before. Prices look decent but I didn't compare with the online sites:
www.matthewsvolvosite.com/forums/viewtopic.php?f=7&t=41595
milesursogood
Bad spring seat . . . Does this need to be replaced or repair immediately?
petek153
Year and Model: 1992 940T
Post by petek153 »
When replacing front strut mount why is it front alignment is needed? If you don't loosen tyrod there is no adjustment to what your replacing. I've done several 850 strut mounts and never had a alignment problem after.I've marked all parts taken apart and when put back everthing realigns due to no adjustable parts. Am I missing something ? Had the first one checked just because everyone says to but the shop said it was fine.
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Ehh...not immediately. Your handling will suffer a lot and the clunking is SERIOUSLY annoying, though.
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
If you do a lot of driving, it could start to affect the wear on the tires negatively. My spring seats were shot before I went to Alaska and back. Obviously, putting a new suspension on AFTER the trip would have been best (tough roads up there)... but I was forced to replace before due to the bad handling and long trip ahead.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
erikv11 wrote:Spring seats is another on of those parts where the aftermarket items tend to just fail quickly. IPD makes a heavy duty one that is OK, otherwise go with Volvo brand or even better, Volvo branded to fit an XC90. The latter are heavier rubber they last a long long time.
That's what I went with for front mounts. Here's how to change them once you've got the strut assembly out:
That's my 2004 V70, but the concept is identical, and the parts will be indistinguishable to you.
petek153 wrote:When replacing front strut mount why is it front alignment is needed? If you don't loosen tyrod there is no adjustment to what your replacing. I've done several 850 strut mounts and never had a alignment problem after.I've marked all parts taken apart and when put back everthing realigns due to no adjustable parts. Am I missing something ? Had the first one checked just because everyone says to but the shop said it was fine.
Thanks Petek. This is very interesting. After my work I had an alignment done, and one wheel was off slightly, but not a whole lot. Who knows, it could have been the car hadn't had an alignment for tens of thousands of miles.
I could look in my notes from the previous owners but I'm too lazy.
Also -> Amazon link
There is slack in the attachment holes for the strut to steering knuckle bolts, so there is adjustment there that affects the steering. But I agree, if you put everything back the way it was then you don't need an alignment, sure. This goes even for tie rods although I would be less likely to trust that.
Truth be told I check my alignment (toe) in the garage before and after a job like struts, and only take it in if I think it is out.
