Couple of problems with my 850
4uvak
Year and Model:
Post by 4uvak »
hey i purchased 93 850glt couple of months ago just now started to drive
i have like not poor acceleration but not 9 second accelerationa as it says everywhere mine probably takes like 11.5
i changed almost everythin there could be (fuel filter,spark plugs ,air filter ) what else can play a major role in acceleration??
second problem just happened yesterday all of the sudden overdrive arrow started to flash any suggestions (relay?)
and my rear brakes killing me with a noise i discovered there are shoul be shims mine didnt had it before so installing them i would stop a noise but still noise appears what else i can do to fix it (turn rotors?)
Please Help! :roll:
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
The rear brake shims (teflon) is sold be www.ipdusa.com Get them and have them installed. Your noise will go away if that's what it is. Overdrive arrow is that either you're in "W" mode (winter) or the P&N switch is going out (park to neutral), therefore your tranny doesn't know when to shift and indicates so on the dash. Other than that, for your loss of boost, I would check all of the little hoses in the engine bay...especially the elbows. Holes in them is a common area for loss of power.
4uvak
Year and Model:
Post by 4uvak »
what hoses can you more specific i am not that experienced with volvo engines just tell what hoses to check like fuel or what they called
MadeInJapan
There are several vacuum hoses in the engine bay, but fortunately for you since you don't have a turbo, you'll have less than me. Just look for little rubber hoses as small as a quarter inch in diameter running from the side of your air filter box, the left side of the engine below the thermostat housing (elbow there that often breaks) as well as another just below the ignition wire rotor (another elbow) and if you take the throttle body cover off, a plastic "tree" with more hoses. You should inspect them for cracks anyway, and if they are- replace them. I've replaced all of mine with silicone ones, but I have a turbo so that would probably be over-kill for your car.
