Abs control module
tlupu81
Year and Model: 1999 V70 GLT
Post by tlupu81 »
I got three of the screws off and the last one is stripped. What's the best way to remove a stripped screw? I heard not to grind them off. Any advice would be appreciated.
Thank you!
asc325is
Year and Model: s60 2.4t 2002
Post by asc325is »
use a dremel and notch the top of the screw so that a flat head will fit and then remove the bolt. Done.
bobice
Year and Model: XC70 1999
Post by bobice »
asc325is wrote:use a dremel and notch the top of the screw so that a flat head will fit and then remove the bolt. Done.
I wonder if you can use a dremel under there, too little space?
asc325is
Post by asc325is »
ive done it. You just need patience.
tlupu81
Post by tlupu81 »
Ya I went out and bought a dremel I'm gonna give it a shot tomm after work.. Atleast the bolt that is stripped is the one on the top left easiest one to get to anyways.. Hope the dremel works!!
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
You lucked out. It's almost always the bolt on the bottom near the firewall that strips.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
asc325is
Post by asc325is »
just dont dremel so far as to destroy the bolt. you just need a tiny little notch to fit the end of the flat head. then contact mattymoo for a replacement. Had a good exp. with him on another forum.
( Just make sure to send your core back or suffer the wrath)
tlupu81
Post by tlupu81 »
Matty Moo wrote:You lucked out. It's almost always the bolt on the bottom near the firewall that strips.
This is one of your modules Matt I'll get mine shipped back to you as soon as I can
tlupu81
Post by tlupu81 »
Well no luck with the dremel I knotched it down too much so I don't know what I'm gonna do now I am very frustrated with this I shoulda just took the damn part to a mechanic and had it tone the right way
bobice
Post by bobice »
Before doing that, you might want to clean the two connectors first really well with contact cleaner. Cleaning the contact solved my problem for now.
