Jiffy Lube
kgrichwine
Year and Model: 2002
Jiffy Lube
Post by kgrichwine »
Is Jiffy Lube competant enough to change automatic transaxle fluid in a XC70 or should I have a Volvo mechanic do it??
JDS60R
Been thanked: 3 times
Post by JDS60R »
Volvo mechanic
Retired
kgrichwine
Thanks for the advice! Had the oil changed and went with the synthetic 5-w40 and they wanted me to upgrade the oil filter, since I was using synthetic oil, for an added $13! What is a oil filter upgrade!?! They quoted $149 for a tranny fluid change. Any idea what I should ecpect to pay ?
RaymanSean
Year and Model: V70 XC, 2001
Post by RaymanSean »
I would budget at least $500 to have it done right. Not saying that it can not be done right for less. Also you should strongly consider doing simple things on your car i.e. oil changes and belts yourself. I have seen too many cars come back from a lube shop with the oil plug crossed and threads stripped out of the pan.
rmorse
Year and Model: 96 855R
Post by rmorse »
^This
On my moms S60, we had to cut the oil drain plug and drill it out becuase it was on there so tight from when she went to the garage to get the oil changed cuz we weren't home. Keep in mind, I'm not talking about "I put a wrench on the plug and it wouldn't turn" stuck. I'm talking about it not turning after we used heat, PB blaster, impact driver, hammer drill, cheater bar, etc. We ended up tearing the plug a bit and then decided to just cut/grind it the rest of the way. The F'ers musta used an impact gun when putting the plug on and buried it into the oil pan.
Moral of the story: Do your own work. No one but me touches my car.
Volvos rock3
Year and Model: v70xc, 2002
Post by Volvos rock3 »
It was $230 at the dealer last time I had it done, 02 V70XC.
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
priapism
Year and Model: 01 S60
Post by priapism »
Jiffy Lube will use a flush machine, which is bad for internals.
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
MyVolvoPartsOnline
Year and Model: S70 1998
Post by MyVolvoPartsOnline »
I hope they use the right fluid. Did they charge you for a filter? There is no trans filter you can change out, something sounds a little fishy. You are talking trans fluid right?
Been thanked: 472 times
Post by cn90 »
JiffyLube employs criminals from prison, FYI.
kgrichwine
The filter upgrade I was refering to was for the oil filter.
