04 XC-70 drive shaft turns but not the rear wheels
i replaced the transfer case 3 months ago how do i check the joint at the rear of the drive shaft
rear drive shaft
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Was the haldex AWD unit at rear diff or the angle gear just behind engine that you replaced?
Have you checked the fuse in the REM for AWD unit?
The joint at rear of shaft would cause severe vibration if it failed in a way that it didn't transmit rotation into AWD unit.
HIjimmy57 wrote:Was the haldex AWD unit at rear diff or the angle gear just behind engine that you replaced?
THANKS FOR HELP
I REPLACED THE ANGLE GEAR . I CHECKED THE FUSE IN THE CARGO AREA ALL WHEEL DRIVE CONTROL MODULE FUSE IS GOOD
i was told it is the pressure sensor. The pressure sensor is mounted on the inside of the Differential Electronic Module (DEM) which is bolted to the side of the AOC which is connected to the front of the rear differential. Removing the DEM will require the draining and replacing of the AOC oil. Part # for pressure sensor is 30651694.lynnemay wrote:HIjimmy57 wrote:Was the haldex AWD unit at rear diff or the angle gear just behind engine that you replaced?
THANKS FOR HELP
MyVolvoPartsOnline
- Year and Model: S70 1998
We sell it for $95 and will ship it for free. Includes full warranty good at any dealer in the nation.
pressure sensor replacement. I have a friend WHO HAS A LIFT WITCH MAKES IT A LOT EASIER.THE PRESSURE SENSOR IS IN A SMALL BOX ON THE FRONT OF THE Differential. REMOVE THE COVER 2 SMALL ALLEN HEAD SCREWS DO NOT REMOVE THE SENSOR UNTIL YOU ARE READY TO REPLACE IT YOU WILL LOSE LESS FLUID THAT WAY. IF YOU REMOVE THE PLUGS AND TRY TO REPLACE THEM MAKE SURE THERE IS NO SMALL ROCKS IN THE WAY
- 5233 Views
Last post by SuperHerman
- 1109 Views
Last post by matt_linegar
- 1779 Views
Last post by erikv11
- 9 Replies
- 3068 Views
- 3601 Views
Last post by bluesguys80
