That is definitely not the part you want - as stated you have posted a picture of a filter.
The check valve does not have to match exactly, it just has to work with the vacuum pressures under the hood of your Volvo. So the Brake Servo Check Valve (in line) # 1228272 will work fine for this purpose, and for example it is under $10 at eEuroparts.com.
Name this Part/Hose
- Has thanked: 312 times
- Been thanked: 818 times
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
To MyVolvoPartsOnline;
Since you have the part (# 9445436) as a complete assembly, what are the numbers on the filters itself? Do it state "Volvo 97 T259? And how many are attached to the assembly hoses? Is it two or three?
Thanks.
Thanks.
98 S70 T5-M Brick for life
You can look up the part number he gave, on a Volvo parts site. The best site for illustrations is here:
http://www.volvopartswebstore.com/showA ... bly=234701
It is number 31 in the picture, so you can see it consists of several hose pieces, 1 tee fitting, and 2 check valves.
deltajets
- Year and Model: v70xc 1998
- Has thanked: 3 times
I have a friend who chased this problem for months with his dodge van.Turned out to be a torn/cracked boot on the filler neck for his gas tank.Might be worth while to look at all the lines that return to the tank since they are the ones out in the open,so to speak.
- 10 Replies
- 5129 Views
Last post by beigg
- 1096 Views
Last post by hadleyet
- 997 Views
Last post by T5AUS
- 1242 Views
Last post by Jazzer
- 2468 Views
Last post by RickHaleParker
