Right, just pay attention for #2.
Basically, while you turn the crank (with a socket on a long extension, go in through the wheel well), there should be minimal resistance because the spark plugs are pulled (no compression). If you encounter resistance or hear a tap or clunk, then likely a piston is hitting a valve. Try to figure out where that is happening, exhaust or intake side, and give the cam on that side a little nudge one way or the other to move the valve(s) and give the piston clearance. Likely you will not encounter this, but pay attention to it as it would be a shame to ruin good valves now, if there are any left.
When the crank is on the mark, the #1 piston is a couple degrees from all the way up in the cylinder (i.e., from TDC), and the other pistons are all recessed somewhere or other in the cylinders. So that is why it is safe to move the cams wherever you want, as long as that crank is pegged on the timing mark.
Timing Mark alignment and adjustment
- Has thanked: 311 times
- Been thanked: 817 times
- LamboSE5
- Year and Model: Empty
ok.
being that this is my situation: ...I would've thought that I'd need the TB attached to do what you're saying...there's no chance of that working though as there wouldn't be/isnt any tension on it. So if i turn the crank wheel, will it even do what I need it to?
LamboSE:
You want to do the #2 and #3 *without* the timing belt on. That is why you have to watch out for piston-valve contact: the engine is out of time due to that jumped timing belt, so with the timing belt off you are going to put things back to where they should be. Only then do you reinstall the belt.
The pulley is indeed ruined but ignore the pulleys for now, you are dealing with three things: left (exhaust) cam and its sprocket, right (intake) cam and its sprocket, and the main crank pulley at the bottom of the engine. Read some instructions for changing the timing belt to familiarize yourself with these parts.
EDIT: You might want to keep the discussion of this the other thread you started, we are hijacking this one ...
- Year and Model: Many Volvos
- Been thanked: 76 times
OK - the harmonic balancer is completely effed - you need a new one. Once you get the new one and get it installed we can work from there on the timing.LamboSE5 wrote:ok.
Lee I think it is the tensioner pulley, not the harmonic balancer?
See also his full thread here, including more pictures:
https://www.matthewsvolvosite.com/forums ... =1&t=43248
You are correct - My bad.Lee I think it is the tensioner pulley, not the harmonic balancer?
I was trying to remember the original post, I though this was the guy that tried to rotate the crank 2 revolutions without the timing belt on and his best hope was that the harmonic balancer came apart in the process.
- LamboSE5
Could the fact that the cam sprokets themselves can be "rotated" slightly "about" the cam shafts when the bolts are loosened be the/a reason why one might be "off" by this much amount?aa_ezra wrote:Ok so finally got the timing belt on, extra hands made it possible.
how do you adjust the sprocket timing with the 10, 20 , 0 and 10 marks?
So here are my current timing marks rotated the engine clockwise about 3-4 times check alignment every time. crankshaft is spot on so is the exhaust cam. the intake is the only problem i think
is it good, or bad?
http://www.ipdusa.com/files/product/321 ... CTIONS.PDF
- 2727 Views
Last post by Williamad33
- 410 Views
- 4201 Views
Last post by MoVolvos
- 1352 Views
Last post by Ozark Lee
- 2967 Views
