One tail light not working (right)
priapism
Year and Model: 01 S60
Post by priapism »
It's not the bulbs, I've replaced them with ones I know work (they work on the other side). The brake light works as does the signal. I don't see any fuses out. Is there something I'm missing? I don't see how it could be the board the lights go in since the signal that sits on the same board works. Or am I wrong?
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
priapism
Post by priapism »
I swapped with the other side's known working unit and that one didn't work either. Only the brakes, no regular tails.
When I was working to fix the blinker I heard a tiny *zap*, I wonder if I shorted something, but what? I can't figure it out.
Juan62
Year and Model: S70 T-5M 1998
Post by Juan62 »
Rear parking lights, right? That zap you herd was a short...thus leds me a fuse is blown or, the short burn the wire and no contact. Check those things, and if necessary, re-solder the wire thats burnt with new one.
98 S70 T5-M Brick for life
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
It may be a good idea to look at the shunt RSH5 in the cargo compartment (its location on page 24 of the following document).
Be patient it takes time to download.
https://www.matthewsvolvosite.com/downloads/2001_S60.pdf
You have the circuit diagram on page 48 (PDF) and it is unit 20/33.
It can be wrongly inserted or burnt. Smell it to see if it hasn't overheated. You can interchanged it with RSH4. The trouble will move to the left if the unit is defective.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
priapism
Post by priapism »
Oops, it WAS a fuse. There are two and I only checked one. Great info though, thanks!
DocJuju
Year and Model: 2011
Post by DocJuju »
Right rear fog lamp out and right rear indicator light out. Bulbs are fine and fuses are fine. Any ideas on what the issue is.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 44 times
Post by 93SCMax »
I had this happen to me once so this might be worth checking.
You will need to remove the tail light lens to confirm, but the metal contact to the bulbs shifted due to plastic tabs breaking that hold the metal plate in place. The metal plate is held by many plastic tabs (not screwed in). If a few break, the metal can move and you don't get a good connection. Sometimes, just removing and installing bulbs can can cause a weak tab to break.
rear tail light lens, backside
Rear tail light.JPG (103.73 KiB) Viewed 5673 times
