ABS and TRACS Dash Lights
Jack Rock
- Year and Model: 1998 V70R
Don't buy a new one, get a rebuild from Matty Moo or fix yourself.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
- Has thanked: 312 times
- Been thanked: 818 times
What Jack Rock said- save yourself a lot of money and get it done right.
volvobaggen
- Year and Model: 850 -1997 B5252s LPG
Easy fix. Just get a E5 female torx and remove the abs controller unit. Pry it open. Remove the jelly-like protective silicone layer. The solder joints normally cracks where the pins from the connector enters the print board. Resolder the joints.
How to remove Abs unit.
Illutstrative pictures on abs-soldering.
There are also numerous threads on this forum with more "in-depth" information on the topic.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
start with the easiest first....inspect your wiring and clean your ABS sensors and tone rings.
It's cheaper to start with the basics before throwing money at it. On a 14 year old car, things aren't always perfect.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Volvo4251
- Year and Model: 98 S90
My ABS module went in June of this year... I had the same exact problem. Unfortunately, these go out on 850's quite often. A used runs for about 400 bucks, but no guarantee the same problem wouldn't happen again. A new one will set you back about 800 dollars. I went ahead and got the used one, I've had no trouble since!
Drive Safely.
2007 Volvo XC70 Adventure Series
1998 Volvo S90
Previous Volvos:
96 Volvo 850 Platinum
11 Volvo C30 T5
07 Volvo XC90 3.2 AWD
98 Volvo V70 2.5 SE
95 Volvo 850 Turbo
94 Volvo 850
91 Volvo 240 Wagon
90 Volvo 240
89 Volvo 740 GL
1998 Volvo S90
Previous Volvos:
11 Volvo C30 T5
98 Volvo V70 2.5 SE
95 Volvo 850 Turbo
94 Volvo 850
91 Volvo 240 Wagon
90 Volvo 240
89 Volvo 740 GL
Ouch!
The module on the 96 pretty much always fails. So you should never buy a used one, it too is essentially guaranteed to fail.
Get a rebuilt. Much cheaper and if you go with a known rebuilder, actually much better quality than new.
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
The thing is ABS is works even if the light is on. ABS module does a periodic self diagnostic when you're driving. You can hear it happen as a faint electric motor noise in the dash. When this diagnostic fails, the light turns on. Some times the light turns itself off, some times it doesn't, Its very intermittent. Do an emergency stop on wet pavement one day and see if your ABS is functioning. I bet it is. The module has either 2 or 3 functions. The base cars have ABS and EBD, and some cars also have traction control function built in. If the light really bothers you can either remove the bulb from the dash or find another module at the JY for about $5. I have of a whole pile of them somewhere in the garage. I did reflow the solder joints on the one I have in there now but the light turned back on a year later. Now I just don't bother with it because I know the ABS work fine with our without it.
Ambitious but rubbish
JRL
- Year and Model: Several
- Been thanked: 16 times
Not really correct
if the light is on, 99% of the time it's NOT working.
And, to the poster who bought a new one, that was a very poor decision!
A new one is as bad as the one your had and went bad and will fail again!
The ONLY good units are the (properly) repaired units which have good solder joints.
- 22 Replies
- 6190 Views
Last post by hausmeister
- 1802 Views
Last post by CDoore54
- 1824 Views
Last post by Matty Moo
- 2686 Views
- 2483 Views
