Will changing the radio, affect the electrical system? S60
alexandermatthews23
Year and Model: S60, 2003
Post by alexandermatthews23 »
I have an S60, 2003. I bought a Pioneer radio, I want to switch out with the factory radio. My step-dad seems to think that if I change the radio, it will screw up the electrical system and I will need to get it reset by a Volvo dealership. I'm pretty sure just changing the radio, won't affect anything? I have to disconnect the battery first though before I do anything, right?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Removing the radio will not stop other things from working but it will cause numerous fault codes to be in the car every time any fault tracing on the network, if any is done.
The way this is avoided is to have "remove radio" software downloaded which is cheap and takes little time.
alexandermatthews23
What are fault codes, will they actually affect anything? And where do I get that software, and how do I install it in the car?
alexandermatthews23
jimmy57
Post by jimmy57 »
The fault codes could give you a message center message at times but otherwise of no consequence except distracting tech trying to fix car if you have troubles later. The software is a dealer or a very well equipped independent using VIDA they susbscribe to from Volvo.
alexandermatthews23
So basically there would be no issues? I could just put it in, and the only problem would be distracting tech, which isn't really an issue, because they can get around that, right?
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
you are not listening,
the car will ride fine, BUT there will be internal fault codes stored in the ECM. When the car has a CEL light on or is malfunctioning, the tech trying to fix the problem/communicate with the car won't know which codes are significant, etc.
Take the car to the dealer and pay for the remove radio software
alexandermatthews23
Ohh, okay, thank you How much do you think it will cost me for that?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Why don't you call and ask them?!
alexandermatthews23
Haha alright thanks
