Just to clarify things.Papas850 wrote:Ok, it was the ball joint and it is the removeable type. Thanks for all the help.
Still wondering if the axle is held in the trans by a Circlip or not, but it may be a moot point once the ball joint is repaired..
The North American driver's side axle is locked with a circlip into the transmission, the passenger's side axle is held in place with a clamp around the carrier bearing and has no circlip, it just slides out once the carrier bearing clamp is removed.
