Just came out from grocery shopping. Loaded the car, turn the key, no starter. Dash lights up just fine. Gauges all active. No starting motor engaging when key is turned though. Battery cables appear fine as do those to the coil and distributor.
I'm at a loss. Any suggestions before I call for a tow?
Fixed - Good battery. Dash lights up. No starter turnover
Fixed. For lack of anything else to do while waiting for a tow, I tried jumping it. Started right up. Battery is 5 1/2 years old so, despite the fact that it seemed to be fine, I guess it lacked the CCA to actually engage the starter motor.
Cheers all!
Cheers all!
2x '98 V70 AWD (one white & one black)
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
A load test of the battery would be a good test to run.
You may also have possible cable issues. A volt drop test
for a car this age is good preventative maintenance.
Be a bummer if the jump didn't work next time!
Yes, agreed on all fronts. My gut tells me that the battery isn't the core issue, just a symptom. I think there is an underlying cause which I haven't found yet.
Thanks for the suggestions.
Billc1015
- Year and Model: 1994 855 turbo
Did the lights on the dash go dim when you tried to start?
I am here: http://maps.google.com/maps?ll=40.285111,-75.287515
No, not for the first 6 to 8 tries (over about 10 minutes) at least. Eventually I did wear the battery down with my repeated attempts to start the car but initially it appeared fully charged and functioning normally.
- BEJinFbk
A bad cable to the starter wouldn't affect the B+ loads.
Just not enough current for the starter. Hence, Volt Drop test.
Billc1015
Could also be a bad or misadjusted pnp switch. If the contacts inside are dirty or it is out of alignment you won't be able to start it. Try to move the shifter back and forth through all the gears and then try to start it.
I am here: http://maps.google.com/maps?ll=40.285078,-75.287497
- 11 Replies
- 2290 Views
Last post by ashlee2319
- 801 Views
Last post by shevolvo45
- 1335 Views
Last post by Ethan Rode
- 998 Views
Last post by brent72
- 15 Replies
- 619 Views
Last post by jonesg
