Man am I having a heck of a time getting off the 36mm nut
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
I'll find out if the LF is good in the morning. :D
By the way, I didn't just finish. I finished at 7pm MST and called it a day. Here's the pics:
Original vs. Femi
Original vs. Femi
The main players in this saga.
Everything.
Everything.
Old axle.
Old axle.
Transmission seal and inner workings.
Pry bars. This was actually the easiest of everything I did. The inner axle just popped out.
Also -> Amazon link
Pauloil
Year and Model:
Post by Pauloil »
wheelsup wrote:Is this what you were having difficulty with?
You really need to get air. An air hammer with a pointy attachment would've made short work of that. Just rubbing it in :).
THIS Picture happens to show cracked rubber brake line, and that is where I was told they break and leak
99 V70XC 158K
95 850glt 188K
obayha
Year and Model: V70 1999 Base
Post by obayha »
So this project was to change out the hub bearing???
Is this a maintenance thing or was something wrong?
I know I ask a lot of question, but I have an axle swap coming up and want to know if I need to plan on doing the hub at the same time..
Thanks for any input.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
matthew1
Site Admin
Post by matthew1 »
Obayha, the hub was going bad. Whump whump whump as I turned right, meaning my left hub, or one of them, was going. At 250k+ miles you might want to do preventative hub replacement, but they're not in the preventative maintenance price league at $100-ish times four.
My mistake was to ruin the axle by hammering it too hard with too hard a sledge. Perhaps they make 40lb. rubber hammers and this wouldn't have happened if I'd used one.
Without my mistake, things might have gone just fine, and much faster. I would have done the control arm and axle in a few weeks, after increasing my toolset properly, for the jobs.
I took her for a test drive just now, everything's fine. :D
Also -> Amazon link
Xilikon
Year and Model: 2000 V70 XC SE
Post by Xilikon »
Yeah, change those hoses !! I did on mine and some parts are a pita to work with the rust (East Canada winters and road salts !!).
2000 V70 XC SE with 150,000 miles, still going great !
obayha
Post by obayha »
Thanks for the wheel hub info. I will hold off until I hear the Whump,Whump, Whump.I need to fund my axle change first. I'll miss the 50-70 mph vibration when it's gone :lol: . You get use to stuff being there and when you fix it.. it's like.. now what?
Shane
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Then something else goes wrong. Such is your life owning a Volvo. :evil:
After we changed the sway bar links on my car a few weekends ago, I think the right one's loose again. I tried futzing with it last night, and didn't touch the left wheel AT ALL, and now it's making some odd noise from that side. It did drive AWESOMELY for about 2 weeks though before I think the bolts loosened up again :roll:
'98 S70 T5
2016 Chevy Cruze Premier
Choguy03
Year and Model: S40, 2000
Post by Choguy03 »
Same thing happened to me. I put some mild thread locker on it the second time around.
obayha
Post by obayha »
Off 36mm subject.. but did I read on here to tighten the strut nuts with an impact???
Maybe just to much reading during working hours :o .
I would like to say that my Trax/ABS lite has been off after the third try at fixing it.. But then it will be back on today or soon..
This site has been great at teaching me a lot about my Volvo.
Thanks
Shane
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
Xilikon wrote:
Pauloil wrote: THIS Picture happens to show cracked rubber brake line, and that is where I was told they break and leak
That car is long gone, sold for scrap...
1995 850 GLT Wagon w/ 200,000 miles
