What type of DIY'er are you?
- Has thanked: 2864 times
- Been thanked: 1332 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
PCV and Timing belts are NOT on the same level.
Just sayin
Just sayin
'98 S70 T5
2016 Chevy Cruze Premier
You had your chance for input in the moderator lounge!jblackburn wrote:PCV and Timing belts are NOT on the same level.
Just sayin
(I know you had a hellish time with your TB, and that's a shame. Luck of the draw?)
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I put my DIY in my sig line and thank the one who gave the best write-up.
PCV and TB change are pretty close to the same, as long as you don't throw in changing the seals also, with a 14 inch drill
Did struts also before joining this forum. I thanks someone higher up on that one. Had no idea what I was doing.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I'll do anything BUT rebuild an engine or transmission. Everything else is nuts, bolts and using your head...and having the right tools.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
I have never needed to rebuild a Volvo engine or head. When I first started driving Volvos I got a core engine with the idea of rebuilding at my leisure preparing for what I thought would be the inevitable. It hasn't happened yet. You might ask why was I so concerned about having a spare motor ready. In my past I had another "V" car..... Chevy's Vega. I also had an overly stubborn attitude about making the car last. Rebuilding, decking the block, etc. were regular activities. The car was a superb course in how to repair everything and often!
1999 V70, 1993 940, 1992 740, 1990 740
Billc1015
- Year and Model: 1994 855 turbo
I have pretty much done everything except body work. Granted I was a tech at a Volvo dealer for a few years and I am currently a tech at a Subaru dealer so I have just about all the tools I need as well as a lift to work on.
I am here: http://maps.google.com/maps?ll=40.334585,-75.130858
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
I will break and engine down and that the block sent out to be done, but I will not try and bore it myself. It is just better to have a pro do that. I am also with you on the transmission too, but I think I would try it if the car was not a DD.Matty Moo wrote:I'll do anything BUT rebuild an engine or transmission. Everything else is nuts, bolts and using your head...and having the right tools.
