Correct, but it's not a problem.007 wrote: Am I right?, I just watched on ebay and it seems the newer light has 5 bulbs, and the older (03-06) just 4, please confirm.
Thanks.
To change the rear lights on my 2004 XC90 to the 2008 ones, I did as described here.
Fortunally, Had I saved the old ones, so I can make this little how-to-do
Remove the small triangle floor piece.
Pull the black tap, and remove the interiorpiece the covers the rear taillights.
Unscrew the two nuts, that holds the lamp.
Here is the new and the old one, side by side.
And from the back. And as noticed there is 5 bulbs on the new one, and 4 on the old.
But is only because the rear light uses 2 bulbs, instead of one. You can see the wiring with grey and white wires to these two.
So nothing to worry about.
The Wires that goes back the cars wiring is exactly the same.
The right one is from the old light and the left is the new.
And the two wirehousings that connects the cars wiring. Still the same.
This worked perfectly on my car. But I can't guarantee for others cars.
