Sounds like cheap plastic
diveshark09
- Year and Model: 2006 S60 2.5T
My 2006 S60 2.5t has a cheap plastic sound coming from the the console between the seats.Not the slide piece, the one with the arm pad. When you rest your arm on it creeks and cracks.Dosent really crack but you get the idea.Other people must have the same problem?So how do you fix this? Thanx in advance
dufferdude
- Year and Model: 1995 T5R Tgul
In VR the seat makes the same noise you're talking about, center arm rest quiet. It's annoying to me. I read somewhere the dealer has a TSB?
1999 V70R #19 1995 T-5R #607
JRL
- Year and Model: Several
- Been thanked: 16 times
Thin felt or foam tape
Start tracing where you think the noise(s) are coming from, remove pieces, tape the butting areas/ joints, replace.
(WORKS)!
It IS cheap plastic, these cars are full of it all over.
On wagons I remove all the rear panels and painfully start taping the entire area and when i do this, an old Volvo can be as tight and quiet as (most) new ones! (Some are bad right off the bat),
so sometimes this is necessary on new cars
(WORKS)!
diveshark09
Thanks time to get some tape.
jcmahoney
- Year and Model: 1999 V70 GLT
My dash does this ( '99 V70 ). I've squeezed a shim in between the dash and windshield, which pretty well stops it. When I replaced the pollen filter last, I re-torqued some bolts that held the dash to the firewall (they were very loose) but this did nothing....
Thoughts?
The tape is a good plan. Those rattles are maddening.
Thoughts?
- 1063 Views
Last post by ZionXIX
- 814 Views
Last post by Sommerfeldt
- 1189 Views
Last post by polskamafia mjl
- 1625 Views
Last post by kcodyjr
- 2010 Views
Last post by Prairiemaster1
