Ive been losing oil and recently my street turned into a rainbow. What can I do about this? Do i have to replace that pipe?
Thanks
S70 GLT oil leak
UCONNs70GLT
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I think the area you're pointing at is a brake line to the back of the car.
I think your oil is coming from above - most likely a bad turbo drain pipe seal or a blown rear cam seal. They're both common culprits.
Get the nose of the car up on a curb or something and get under it with a flashlight so you can better pinpoint the area the oil is leaking from.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Also, if you have not service the PCV system lately you need to do so. It can cause blown seals.
UCONNs70GLT
Thank you so much guys, ended up being the rear camshaft seal. Had it replaced and it cleared up! Almost lost my car
Thanks again
Thanks again
98' S70 GLT 106k
