Hello everyone,
I got my 740 running now after sitting a year or so...
The steering wheel is really hard, it is almost impossible to turn wheels when stop and really hard to turn when driving slow.
I checked the fluid and it is fine, didn't see any leaks, belts look fine, everything seems like working but something is wrong..
Anybody has an idea?
Thanks in advance...
91 740 steering is really hard
neworleans
- Year and Model: 2007 S60R
Nuttydriver
- Year and Model: 1998 v70 xc
Pull your serpentine belt and see how easily the power steering pump spins. It sounds like it's not pumping to me.
Vehicles:
98 Volvo v70xc
99 dodge Dakota
81 chevy chevette
89 chevy k1500
98 Volvo v70xc
99 dodge Dakota
81 chevy chevette
89 chevy k1500
neworleans
thanks for your reply but i never dealt with belts, can you pls somehow show me how to remove serpentine belt?
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
A 740 uses V-belts, not serpentine. A slipping crank pulley (harmonic balancer) can cause power steering symptoms.Nuttydriver wrote:Pull your serpentine belt and see how easily the power steering pump spins. It sounds like it's not pumping to me.
1988 Volvo 760 Turbo Wagon
That sentence worries me. Would that be the same with a '98 S70 T5 SE? The steering is really hard at startup, requiring two hands to turn the wheel. Once turned from lock to lock about 3-5 times, it's "fairly" normal....i.e.: loosens up significantly.lummert wrote:A 740 uses V-belts, not serpentine. A slipping crank pulley (harmonic balancer) can cause power steering symptoms.Nuttydriver wrote:Pull your serpentine belt and see how easily the power steering pump spins. It sounds like it's not pumping to me.
