in 1st gear, move up to 2nd gear, clutch fully released fine, pressed accelerator to pick up speed, foot off accelerator and car then jumps back slightly?
edit: and i dont mean slowing down, more as if you actually pressed the brake
Possible explanation for this?
Standard transmissions operate via clutch paks, pressure plate & throw out bearing. I would check these for wear & adjustment. Inpection of drive shaft, universal joints and drive shaft/rear differential for play/wear might be needed.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That's normal. Lower gears will "brake" more. It's the same effect almost as dropping an automatic back down to 1st gear while driving around 20-30 mph - it will abruptly slow you down.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Very normal in 1st and 2nd gears. Not so much in 3rd and not at all in 4th or 5th.
