Got a 2000 VOLVO S70 GLT with 132K miles on it. All of a sudden the CEL came on with code P1171 (Fuel Adaption, Bank 1) and the car is idling very ruff and stalls sometimes when the engine is cold?
Could that be under the 10 year ETS Warranty?
Is CEL Code P1171 related to ETM Problems?
Just did a Google search on your code and lots of folks had this code with a bad Mass Air Flow (MAF) sensor. Try unplugging the MAF connector and see if it cleans up the connector, or idles better with it unplugged. I think your car substitutes a default value when it's unplugged
DonWillson
- Year and Model: 2000 V70XC
The mass air flow meter and the ETM both measure the air flow. The mass air flow meter actually measures the flow through it by a hot wire aneometer. The ETM by a 'look up' table that says something like, "if the throttle is 40 degrees open the air flow should be 30 cfm" If these do not agree then it can set a code. But which is the real problem. I would suspect the ETM. If you replace the MAF at your expense be sure to keep it so it can be replaced if it is not the problem.AP wrote:Got a 2000 VOLVO S70 GLT with 132K miles on it. All of a sudden the CEL came on with code P1171 (Fuel Adaption, Bank 1) and the car is idling very ruff and stalls sometimes when the engine is cold?
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
I had my ETM for free at VOLVO and the CEL went out. I've been driving the car for 3 days now and the car runns smoother when the AC is on. Also the ruff idling disappeared with the upgrade. All good stuff for my car!
thanks for all the good info!
- 2074 Views
- 944 Views
Last post by agreenwo
- 3365 Views
Last post by krenekj
- 36 Replies
- 2339 Views
Last post by ericmci
- 925 Views
Last post by Kokonradus
