speedo replacement
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
speedo replacement
have the dreaded dead speedo in my 90 740 - given all the trouble others have had with the re-cap procedure i figured a straight replacement was the better option - i was able to pull one (yazaki) from a donor cluster but it has substantially higher mileage (100k km more!) - is there an easy way to wind back the donor before i install it?
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
shegarty
don't think i'll ever sell her - i try with all things to keep everything as original as possible - since i have the old speedo removed separated from the cluster i just thought that i would ask around - i had originally thought of replacing the entire cluster but the donor is missing the voltmeter and turbo gauge - probably just easier to pull the original cluster and drop in the "new" speedoshegarty wrote:There's also always the old log book that just says "Odometer replaced at 123456km with used unit showing 234567km." Depends on whether you're planning to resell it.
i wish it were that simple here in Ontario - we have report mileage each time we renew our registration/road tax or transfer ownershipSenor_Turkey wrote:in a lot of states here in the US, anything over 10 years old is exempt from mileage requirements and/or disclosure, so it wouldn't matter anyway, except for your own peace of mind
