STAGE 1 S80 T6 MAKE OVER
ACk
Year and Model: 2000 Volvo S80 T6
Post by ACk »
OK, so i purchased this awesome 2000 T6, with 70K on it, i knew i had to go to work, because im just sick like that lol..
parts i wanted reaplced and ordered from http://www.autopartswherehouse.com
new Elrig intake gassket
new VVTi gasket
new oil trap
of ocurse found many servicable/replaceable parts along the way. i will post pix as well.
ACk
Post by ACk »
i spent a few hours cleaning and scrubbing the block, of course there was alot of cleaning that had to be done, make sure you cover/plug the dip stick hole, oil trap ports, as i had not done that, the results is going to be removing the oil pan to remove excess water if any. thats the next step with cleaning the oil pan and oil cooler lines.
ACk
Post by ACk »
i removed/scraped off that factory foamy "heat shield?" , anyway you will see what i replaced it with, something Volvo should have thought of back then i guess...
while the intake manifold was removed, i took it to a DIY car wash and covered the entire thing with GUNK GEL degreaser, and then blasted it with hot pressurised wash. not bad huh?
ACk
Post by ACk »
a few more pix for you volvo lovers, the sun is going down , so i will try to post some more pix tomorrow. happy NEW YEAR , stay safe. :D
some goodies i bought for the make over... wire loom, a complete set of hose clamps, COOL IT heat insulation, great stuff. $20 at auto zone, but you might find it cheaper elsewhere, i dont know....yet.
cleaned the ETM while i was at it, didnt really have the common surging problem i have read about..used some shop towels and q tips and good ole' carb cleaner. DO NOT WASH IT.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I can see that you've left the coupling on the block for the PCV box. This is where much of the crud in the block accumulates so be sure to remove the short hose and scrape out the port where the lower PCV port connects. If you can get a bottle cleaner in there and get it to go 90 deg this will do the trick. You may need to change the oil because some of the crud will drop into it.
ACk
Post by ACk »
Hello, yes i did remove the lower coupling hose, and cleaned it out, i forgot to include a pic :) , i do need to find a vacuum hose routing digram, for the hoses i replaced.... i should have marked them... ill figure it out.. oh and yes im removing the oil pan and going to comepletely clean it and steam wash it in a few days, then to the 4T65E removal.. going for an overhaul... cheers!
Looks like you are headed in the right direction. It's not too many people put that much time & effort into a T6. Good to see.
Be sure to replace the pick-up pipe o ring seal and the two pan o rings as well. That will make sure your oil delivery to that sweet twin turbo six remains constant.
It may be worth your while to replace the valve body with the upgraded one that has been put into use by other manufacturers. Not too sure if the 'box itself saw some upgrades. The valve body is definitely different on GM products.
http://valvebodyxpress.com/prodView.php?theId=150
Perhaps someone can chime in here.
ACk
Post by ACk »
WOW yessss, thank you for reminding me, IM HAVING A HARD TIME WITH THE VACUUM ROUTING AND THE CHECK VALVE DIRECTIONS FROM THE MANIFOLD OUT... i know the bypass valve and the couple of other ones that goes underneath the air filter neck , however the one hose coming out from the intake manifold itself where its divided into 3 pieces, i cant seem to remmeber how i removed it and/or what direction its placed decpite the 2 different hose sizing.... any idea? i have been searching under my hood (decal) and online, i cant seem to get a clear pic/diagram of the vacuum routing and one way check valve direction.... please help !!!! thank you
I'm not really your man for S80s. I have a copy of Vadis and was able to create the docs:
Hope these diagrams help.
S80 T6 intake 1.pdf
(331.56 KiB) Downloaded 966 times
S80 T6 PCV1.pdf
(256.57 KiB) Downloaded 1163 times
ACk
Post by ACk »
THANK YOU KINDLY !!! :)
