Hi,
I am about to pull the starter out of my 95 850 Turbo wagon and I noticed at Autozone they have the California starter and the non-California starter. I dont know what emmissions have to do with a starter but those are my options. Has anyone replaced one of these and which did you purchase? Also...does this starter come out of the top or can be accessed through the top of the engine compartment? Seems so from what I've read. About to undertake this myself and dont have a lift. any help appreciated.
Thanks!
California Starter? 850Turbo Wagon
850TurboWagon1995
- Year and Model: 1995 850 Turbo Wagon
- Year and Model: Many Volvos
- Been thanked: 76 times
Welcome to MVS,
Like you, I have no idea what a California starter is unless it has different physical dimensions so as to clear some goofy California emissions device that is near it.
Changing the starter is not that big of a deal, remove the fan shroud and you should be able to reach in below the intake manifold and unbolt the old one and its wires. Much of this is done by feel rather than sight.
850TurboWagon1995
Thanks. I just tried to remove myself, bolts are locked....going to sell it instead of sinking money in it....just spent 460 on replacing cam and crank sensors. Great car at the end of its life though
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Get a can of PB Blaster and give all the bolts a good soaking. No sense in getting rid of a running car over something as small as a starter motor.
The fan shroud will lift out of place and give you a lot more room to work on the starter. Just disconnect a few things and remember where they are.
'98 S70 T5
2016 Chevy Cruze Premier
850TurboWagon1995
Shroud isnt the prob, but i hear you. Has 170k. Iles, lots of things starting to go wrong
850TurboWagon1995
Thanks...still torn onkeeping it.
850TurboWagon1995
Im not going to ditch it just for that. It has 170k on it and it is eating me up financially. Now low pressure boost, cuts out on me after driving a few hundred yards...maybe fuel filter? I dont know just running really rough
850TurboWagon1995
Mission Accomplished! Seriously though, it might be easy on an 850 without a turbo but you have move a LOT of stuff to get to the bolts on the starter, especially where the transmission dip tube is bolted in with a bunch of cables directly in front of the lower starter bolt. Fan shroud did come out easy.
Another item to note is that i had gapped new spark plugs per some info on the website (not this one) INCORRECTLY and that I suspect was the cause of the poor performance....i just put the old ones back in and noticed immediate improvement. For others, the correct gap is .028.
Thanks Forum!
Thanks Forum!
- 678 Views
Last post by phils94850
- 912 Views
- 619 Views
Last post by polskamafia mjl
- 11 Replies
- 1991 Views
- 1258 Views
