tweaked idler pulley
boonmariachi
Year and Model: 850 non turbo , 1996
Post by boonmariachi »
so i've gotten everything fixed. then the belt started walking off the alternator pulley!!! :evil: so many problems with this car......then i take a closer look and the idler pulley is tweaked!!! so how do i get this off, of course i can't find anything on it so please help me out!!!
2012-01-29 12.26.07.jpg (635.21 KiB) Viewed 2017 times
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
What does TWEEKED mean? It's not sitting straight? It should have a bolt on the front of it. :?
boonmariachi
tweeked means not sitting straight and aligned with alternator pulley as you can see in the picture, there's a cover on the middle of the pulley but can't seem to get it off!!
rspi
Post by rspi »
IDK, maybe someone will help soon. I'll check my repair manual.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Always thought that "tweaked" meant modified for more performance, sometimes by a backyarder. ie: I have a cool ride with a "tweaked" motor.
Guess I'll have to look out for that in future!!
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Your idler pulley does look quite offset on the image. See attached file for idler positioning - hope this is your case; if you have a different engine please specify engine type (e.g. B5252FS) and I will post another procedure.
Cheers!
Aux Belt Arrangement 850.pdf
(94.13 KiB) Downloaded 288 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Pauloil
Year and Model:
Post by Pauloil »
yours looks shot and out of alignment. get new one and all should be well, and your belt will last longer!
99 V70XC 158K
95 850glt 188K
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I'm not sure if it's tweaked- there are grooves on the belt that should keep it on.
I'm wondering if the tensioner is worn out, not putting enough pressure on the belt?
It would be very hard to lift- you really can't lift it without a tool.
dwyerob
Year and Model: 1994 850
Post by dwyerob »
One of your pulleys is wrong, either the alternator or idler. I bought an alternator with a pulley that had a spacer on it that pulled it away from the other pulleys. Your picture looks exactly like mine did. I had to order a pulley from the dealer but you could find one in a junk yard. Hope this helps.
Rob
byeboy
Year and Model: 850R, 1997
Post by byeboy »
I see that bolt cover in the (great!) attachment. How does one remove that cover to get to the bolt? The pulley could be shot, with the center hole wallowed out, which would also explain its lop-sidedeness...but I doubt it...
