Hi folks,
I'm sure this has been discussed, but I couldn't find the answer. My 1998 V70 T5 does not warm up all the way when it's below 30 degrees F so the heater isn't very warm and the mileage is down. We drive mostly highway miles, which is part of the issue it seems as the beast does warm up sufficiently in town.
So, should I stick some cardboard over the radiator? If so, over just part of the radiator? Change the thermostat (less than 1 yr. old) or ??? Your ideas appreciated!
Cheers,
Randy from da Upper Peninsula of Michigan
V70 doesn't warm up
JRL
- Year and Model: Several
- Been thanked: 16 times
Change thermostat AND also your coolant temp sensor would be a good idea
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
30 above ? If so, +1 on the thermostat.rswaty wrote:Hi folks,
Cheers,
30 below? Different story.
DO NOT block the radiator unless it's below 0.
Buy a good quality unit from a trusted parts supplier, don't be tempted by the $2.99 unit on the rack (ask me how I know). Also be aware that multiple temp ranges are available for your vehicle and to be sure you have the correct one, double check by finding the temp rating that is stamped on the thermostat.
1998 NA S-70 150,000 mi
taxi
- Year and Model: V70 2000
With the correct thermostat there should not be a problem keeping engine at correct temperature down to at least -35 degrees celsius, but any colder than that I guess the anti freeze starts freezing
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
To test the thermostat on the car, start the engine cold and grab the radiator hose coming from the T-stat. If it starts getting warm immediately (within a minute or so), then the T-stat is stuck open.
While looking for the part, if you do the "cardboard on the radiator"-trick, keep one eye on the temp gage at all times - you can easily overheat while idling!
Here is a procedure how to test and replace your T-stat - see attached.
vcc-001233.pdf- (99.53 KiB) Downloaded 336 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- Has thanked: 312 times
- Been thanked: 818 times
It is also pretty easy to test the t-stat by taking it out. If it is open when you remove it, well, it is stuck open. Not so relevant for this post but if it is closed, then drop it in boiling water, see if it opens.
