V70 doesn't warm up
rswaty
Year and Model: 1998 V70 T5 134K
Post by rswaty »
Hi folks,
I'm sure this has been discussed, but I couldn't find the answer. My 1998 V70 T5 does not warm up all the way when it's below 30 degrees F so the heater isn't very warm and the mileage is down. We drive mostly highway miles, which is part of the issue it seems as the beast does warm up sufficiently in town.
So, should I stick some cardboard over the radiator? If so, over just part of the radiator? Change the thermostat (less than 1 yr. old) or ??? Your ideas appreciated!
Cheers,
Randy from da Upper Peninsula of Michigan
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Change the thermostat. Even in subzero weather the engine will warm up pulling the car down the road.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Change thermostat AND also your coolant temp sensor would be a good idea
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
rswaty wrote:Hi folks,
Cheers,
30 above ? If so, +1 on the thermostat.
30 below? Different story.
DO NOT block the radiator unless it's below 0.
jdmack
Year and Model: s70 1998
Post by jdmack »
Buy a good quality unit from a trusted parts supplier, don't be tempted by the $2.99 unit on the rack (ask me how I know). Also be aware that multiple temp ranges are available for your vehicle and to be sure you have the correct one, double check by finding the temp rating that is stamped on the thermostat.
1998 NA S-70 150,000 mi
taxi
Year and Model: V70 2000
Post by taxi »
With the correct thermostat there should not be a problem keeping engine at correct temperature down to at least -35 degrees celsius, but any colder than that I guess the anti freeze starts freezing :shock:
BEJinFbk
Post by BEJinFbk »
A 50/50 mix is good to at least -60 F.
Ask me how I know...
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
To test the thermostat on the car, start the engine cold and grab the radiator hose coming from the T-stat. If it starts getting warm immediately (within a minute or so), then the T-stat is stuck open.
While looking for the part, if you do the "cardboard on the radiator"-trick, keep one eye on the temp gage at all times - you can easily overheat while idling!
Here is a procedure how to test and replace your T-stat - see attached.
vcc-001233.pdf
(99.53 KiB) Downloaded 336 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Has thanked: 312 times
Been thanked: 818 times
It is also pretty easy to test the t-stat by taking it out. If it is open when you remove it, well, it is stuck open. Not so relevant for this post but if it is closed, then drop it in boiling water, see if it opens.
