#*%@*#! (expletive) - 1996 850 Turbo
Okay, so I admit, my fiance's Volvo is kicking my you know what. No Spark - except once when it started and ran flawlessly, never again though. Have been trying parts from the junkyard, so far a coil or two or three and just bought three Crank position sensors. Have tried one so far (ran out of time because the one I was removing broke off (that was fun)). Anyway, taking a break and will try to gather my thoughts and do some more research. One question for now - the alarm and immobilizer - any advice on checking/bypassing, or otherwise removing from the equation? Does it actually kill the spark, or just keep the starter from engaging? Any suggestions would be greatly appreciated!!!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
On a 1998, the alarm won't even let the starter turn over.
Have you tried the cam position sensor?
'98 S70 T5
2016 Chevy Cruze Premier
I have not tried the cam position sensor yet, but it;s on my short list of things to try. I still have two more crank sensors to try on the remote chance that the one I tried last night was bad.
Can anyone confirm whether or not the alarm system just interrupts the starter, or does it also interrupt ignition - or both?
Thank You!!
Thank You!!
- Has thanked: 311 times
- Been thanked: 817 times
On my 96s, the alarm will not let the starter turn over.
Order I would check them in: cam sensor, crank sensor, coil.
I believe the alarm system (when engaged) will not allow the engine to crank over. If it cranks the alarm system is not the culprit. I would look at the Cam or crank sensor. Coils seldom go bad. I have a 1997 850 T-5 that I replaced cam, crank, coil and I still do not get spark? So I'm in the same situation.
I think next on the list for no spark is ECU (assuming you checked the coil wire too?). Expensive though - try to just borrow a known working one for a test.
RDEJR
- Year and Model: 850 GLT Wagon, 1996
I had a no spark issue on a 940 Turbo that I was helping a guy work on... turned out to be a bad distributor cap...
Do you have no spark to the plug wires, or on the main coil wire heading into the distributor. I would check that first.
My T5 never chirps tires - it's a slow fat whale from a stoplight. - jblackburn
1996 850 GLT Wagon (Soon to be Turbo!) - Black and Mild
1995 850 Turbo Wagon - Sleeper 'goon.. never giggled so much...
Does anyone know for sure regarding the alarm on the '96 850? Does it just inhibit the starter engagement; or does it also inhibit ignition? I have not tried the cap and rotor yet - I suppose it would be a good idea to change those anyway...
Thanks for the input, keep 'em coming - I promise to try everything until I get this thing running!!
What I know for sure: I have have a 96 850 and have been unable to start before due to the alarm. When this happens, the starter will not engage.june82000 wrote:Does anyone know for sure regarding the alarm on the '96 850? Does it just inhibit the starter engagement; or does it also inhibit ignition? I have not tried the cap and rotor yet - I suppose it would be a good idea to change those anyway...
Before you change the cap and rotor, see if there is spark coming out of the coil like RDEJR suggests. I assumed you checked that but sounds like maybe not.
