Throttle Position Sensor
grr
Year and Model: '98 S70 T5 290k Mile
Post by grr »
1998 S70 T5 290k/miles.
Could not read the check engine light code at the local parts store, so I went to the Volvo dealer (US$126 HOUR !) though they read it at no charge. They did not say what the code was, but told me it was the throttle position sensor and that they wouldn't have time to repair it that afternoon (I had not asked them too). Does it take a long time?
I've never cleaned the PCV system and it has never exhibited any problems.
What is the throttle position sensor and where is it? Other than this sudden appearance of the check engine light the vehicle runs fine.
Thanks in advance,
Jerry
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
It does exactly what it sounds like - senses how much your foot is down on the gas. The car uses this information to determine air/fuel mixture and auto transmission shift patterns.
It's on the very front of the throttle body.
'98 S70 T5
2016 Chevy Cruze Premier
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
Its amazing to me that Volvo dealers get away with such horrific customer service.
Ambitious but rubbish
grr
Post by grr »
I can't see anything familiar on my S70, which is a 5-speed. Is the stick shift different or is the switch buried beneath the accelerator cable unit?
(Yes, they use lots of winter salt up here in Wisconsin)
tjts1
Post by tjts1 »
The TPS is mounted on the opposite side of the TB shaft. Its black plastic attached with 2 screws as in the pic posted by jblackburn. You'll probably need to remove the intercooler hoses to see it clearly. Since there is so much salt on the roads in your area, you might get away with simply disconnecting the plug and cleaning the oxidation on the contacts with some fine grit sand paper. Then reset the codes and see if the problem comes back.
grr
Post by grr »
Thanks guys...I'll order the part.
Jerry
bigdaddylee82
Year and Model: '95 850 GLT+94 parts
Post by bigdaddylee82 »
Try what tjts1 said before ordering a new one. Pull the current one off, get a can of CRC Contact Cleaner (or similar) a wire brush, and go to town on the contacts on the sensor and it's cable. When you put it back together use some dielectric grease. I'm 90%+ sure that'll fix it. If it doesn't, you'll want to clean the cable contacts and use dielectric grease on the new one anyway, so nothing to loose for trying.
- Lee
grr
Post by grr »
Oh...I didn't see his comment. That's good advice, especially in this climate.
Thanks,
Jerry
