Door Panel Delamination
SpeedyPete
- Year and Model: S70-T5, 1998
Hello Friends: I was wondering if their are any other door panels from other models (not S70) which would be a direct fit replacement which do not have the delamination issue? I removed the panels, and had new material sew at the arm rest area, however the foam behind this area has broken down and released. Lesson learned get rid of the foam also. My problem is when I reassembled the door panels I used Sika Flex this is a very durable construction sealant/adhesive and there will be no further disassembly of these panels. Any suggestions? Best Regards to all, SpeedyPete
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
S/V 70 R models.
SpeedyPete
Thank you RSPI: This is what I tried to mimic on the cheap. It only cost me $100.00 for material and labor from a local upholster with the panels out. He worked on the arm rest area only and did nice french seams. The panels looked great when I picked them up and reinstalled them. But one summer later and Darn That Foam!
- rspi
Contact rspi..
Get you an old truck and find a "70 R" model and take it out. Be real nice to the owner and maybe the'll sell the car back to you. LOL Just kidding.
SpeedyPete
Hola all and RSPI
Are their specific years of R models besides 1998 I should be looking for to match my 1998 T5 for fit. I assume 1999,2000 will work also but how about other years? I will be hitting the dismantlers soon.
JRL
- Year and Model: Several
- Been thanked: 16 times
1998-2000 all the same
That's it
That's it
SpeedyPete
Thank you J
Is their any difference from wagon to sedan front and back doors? Best Regards, SpeedyPete
- rspi
Contact rspi..
No, those doors are actually interchangeable.
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
Look for 98'-'00 t-5 SE door panels sedan or wagon. They're easier to locate than R door panels. I found a set for $100 and swapped them up on my '98 V70.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
JRL
Depends on where he is
There are basically no SE cars and panels in the US unless someone brought them in
- 579 Views
Last post by obayha
- 1781 Views
Last post by VolvoChef
- 756 Views
Last post by mika
- 2675 Views
Last post by Mike Langlois
- 815 Views
Last post by Volvo_CV
