Tight spaces.
Wiggled a bit harder to pull the air cleaner base out, i guess. When putting the air cleaner base back, noticed the retaining male pin, closer to the ABS module, was broken, partly peeled-off. Forcing the box back to snap-on further deteriorated the retaining pin. Now the pin is attached to the air cleaner base, but not attached to the seat, its base. The plastic piece has broken-off.
Is there a replacement part - or a simple fix?
The air cleaning unit is intact though. However, it rocks/yaws a bit between the battery and the brake fluid reservoir. It appears, the engine vibration is making the air cleaner's hose to front grill come loose, and the positive (+) battery post cover often comes off in rubbing against another hose. I check it after each ride, and wiggle it back to normal.
I can't be asking my wife for the hot glue-gun for this repair. :D
Thanks!
Broke air cleaner base retainer clip during ABS...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I guess you can go to the junk yard and get one.
keepersboy
- Year and Model: v70 1998 850t 1994
One of my cars has had this broken for years, without any problem. If your worried just put an elastic cord or something to hold it in tight, but I don't think its going anywhere. I'm sure the new base would cost a fortune from volvo.
xHeart
The junkyard visit was disappointing. However, I found the part number, see item #8 in the above diagram. I will order item 8 and rubber cushion #11 this weekend.
What to watch for when I do this part replacement?
Thanks for your help, All!
xHeart
Today is Sat 2/11. I now have the replacement bracket and rubber cushions. The air box cleaner base is removed. With the help of WD40, I have successfully unscrewed the two 1/2" bolts holding the bracket in place.
I am not sure now how to proceed with the hose. It goes through the bracket like thread through a needle. Therefore, I ask, could I disconnect and reconnect the hose at the conduit (circled in red)? Should i expect fluid come out? Please help!
Thanks so much.
Thanks so much.
- rspi
Contact rspi..
I believe it's just some kind of air/vacuum line. I have watched a guy disconnect that thing about 5 times working on his PNP switch.
xHeart
The hose to the right of the conduit flexes, but to the left it is firm-fix. I am preparing to pull it off after a quick prayer.
It is 7:00 p.m. job is done. Also replaced the two worn rubber cushions. Air box now sits the way it should, firm.
Trans D&F is next.
Thank you R!
Trans D&F is next.
Thank you R!
xHeart
Oops!
Wait... the fuel guage needle is not where it should three days after the fix.
Searching MVS for fuel guage malfunction on 1997 850 2.5l base.
- 10 Replies
- 2246 Views
Last post by volvolugnut
- 1936 Views
Last post by rspi
- 9 Replies
- 1215 Views
- 1118 Views
Last post by crisnumbertwo
- 1623 Views
Last post by oragex
